Bluefen
Feb 26, 2017Initiate
Odd name for connected device
Hi, I have one device which is logging in very strangely, it doesn't display a MAC address in stead it shows /OrbiDevname2>. It also shows the device as being a Wired connection when in fact it i...
-Wes-
Mar 25, 2017Initiate
Yes, I have this same issue - I'm on the newest firmware and it needs to be fixed!
DarrenM
Mar 27, 2017Sr. NETGEAR Moderator
Thanks for the input I will bring up the attached devices still having some issues.
DarrenM
- PapaMikeMar 27, 2017Star
Mine is fixed for now.
I decided to relocate my router from the home theater area so I routed all connections through a wall port. That included the modem. All devices were disconnected. After reconnecting the modem and restarting the router, all devices are now identified correctly including the User name of device and MAC address.
So, perhaps a disconnect/reconnect of modem is what "fixed" the errononeous names and ID's.
