bisu-fan's avatar
bisu-fan
Odd ping between satellite and router since 2.5.1.8 update
Ever since updating my orbi RBR50 and RBR 50 to firmware 2.5.1.8 last week, my internet is very unstable, and pinging my base router shows that there is a lot of erratic ping times between my satellite and router. Anyone else having this issue? I've factory reset my units (does a factory reset downgrade the firmware as well?) and tried re-updating the firmware to 2.5.1.8. I've also tried enabling/disabling mu-mimo, fast roaming, 20/40 coexistence, wmm and none of these are fixing the unstable ping. I'm at my wits end and I have no clue what else I can be doing because I feel like I've basically changed every setting in the orbi menus. Thanks in advance! ping test to 192.168.1.1 -t Reply from 192.168.1.1: bytes=32 time=77ms TTL=64 Reply from 192.168.1.1: bytes=32 time=4ms TTL=64 Reply from 192.168.1.1: bytes=32 time=3ms TTL=64 Reply from 192.168.1.1: bytes=32 time=4ms TTL=64 Reply from 192.168.1.1: bytes=32 time=4ms TTL=64 Reply from 192.168.1.1: bytes=32 time=2ms TTL=64 Reply from 192.168.1.1: bytes=32 time=1ms TTL=64 Reply from 192.168.1.1: bytes=32 time=2ms TTL=64 Reply from 192.168.1.1: bytes=32 time=62ms TTL=64 Reply from 192.168.1.1: bytes=32 time=37ms TTL=64 Reply from 192.168.1.1: bytes=32 time=123ms TTL=64 Reply from 192.168.1.1: bytes=32 time=13ms TTL=64 Reply from 192.168.1.1: bytes=32 time=2ms TTL=64 Reply from 192.168.1.1: bytes=32 time=11ms TTL=64 Reply from 192.168.1.1: bytes=32 time=3ms TTL=64 Reply from 192.168.1.1: bytes=32 time=3ms TTL=64 Reply from 192.168.1.1: bytes=32 time=4ms TTL=64 Reply from 192.168.1.1: bytes=32 time=4ms TTL=64 Reply from 192.168.1.1: bytes=32 time=151ms TTL=64 Reply from 192.168.1.1: bytes=32 time=4ms TTL=64 Reply from 192.168.1.1: bytes=32 time=3ms TTL=64 Reply from 192.168.1.1: bytes=32 time=2ms TTL=64 Reply from 192.168.1.1: bytes=32 time=105ms TTL=64 Reply from 192.168.1.1: bytes=32 time=40ms TTL=64 Reply from 192.168.1.1: bytes=32 time=5ms TTL=64 Reply from 192.168.1.1: bytes=32 time=5ms TTL=64 Reply from 192.168.1.1: bytes=32 time=4ms TTL=64 Reply from 192.168.1.1: bytes=32 time=3ms TTL=64 Reply from 192.168.1.1: bytes=32 time=5ms TTL=64 Reply from 192.168.1.1: bytes=32 time=5ms TTL=64 Reply from 192.168.1.1: bytes=32 time=3ms TTL=64 Reply from 192.168.1.1: bytes=32 time=4ms TTL=64 Reply from 192.168.1.1: bytes=32 time=11ms TTL=64 Reply from 192.168.1.1: bytes=32 time=120ms TTL=64 Reply from 192.168.1.1: bytes=32 time=40ms TTL=64 Reply from 192.168.1.1: bytes=32 time=6ms TTL=64 Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
  • I am not entirely certain there is a problem.
    Could you please explain how the device measuring ping time is attached?
    Ping latency can vary a lot.
    For example, I have a Windows computer connected with ethernet cable to my RBR50.
    Ping times are typically 1ms.
    Pinging 192.168.1.1 with 32 bytes of data
    Reply from 192.168.1.1: bytes=32 time<1ms TTL=64
    Pinging my RBS50 satellite is not as quick:
    Pinging 192.168.1.5 with 32 bytes of data
    Reply from 192.168.1.5: bytes=32 time=3ms TTL=64
    Reply from 192.168.1.5: bytes=32 time=2ms TTL=64
    Reply from 192.168.1.5: bytes=32 time=8ms TTL=64
    Reply from 192.168.1.5: bytes=32 time=4ms TTL=64
    I also have a Linux laptop connected to the 2.4G Orbi channel (it's old, but runs Linux just fine).
    Pinging the router from this WiFi connected laptop looks like this:
    PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
    64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=5.07 ms
    64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=2.65 ms
    64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=3.25 ms
    64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=2.40 ms
    64 bytes from 192.168.1.1: icmp_seq=5 ttl=64 time=3.02 ms
    64 bytes from 192.168.1.1: icmp_seq=6 ttl=64 time=34.5 ms
    64 bytes from 192.168.1.1: icmp_seq=7 ttl=64 time=4.62 ms
    64 bytes from 192.168.1.1: icmp_seq=8 ttl=64 time=5.78 ms
    Notice that the pings take longer on WiFi than on ethernet, and there was one that was 10 times the average!
    Pinging the satellite from this WiFi connected laptop looks like this:
    PING 192.168.1.5 (192.168.1.5) 56(84) bytes of data.
    64 bytes from 192.168.1.5: icmp_seq=1 ttl=64 time=11.1 ms
    64 bytes from 192.168.1.5: icmp_seq=2 ttl=64 time=4.68 ms
    64 bytes from 192.168.1.5: icmp_seq=3 ttl=64 time=6.50 ms
    64 bytes from 192.168.1.5: icmp_seq=4 ttl=64 time=7.61 ms
    64 bytes from 192.168.1.5: icmp_seq=5 ttl=64 time=9.41 ms
    64 bytes from 192.168.1.5: icmp_seq=6 ttl=64 time=5.18 ms
    64 bytes from 192.168.1.5: icmp_seq=7 ttl=64 time=10.8 ms
    64 bytes from 192.168.1.5: icmp_seq=8 ttl=64 time=5.38 ms
    Again, uniformly longer than the ethernet and longer than directly to the router.
    • bisu-fan's avatar
      bisu-fan
      thanks for the response! yeah i'm pinging from my desktop which is connected to a satellite which is connected wirelessly to the base router (roughly 30 feet in between).
      What's weird is that during the day, this ping issue is nonexistent, the ping is always low and around 10ms. Only during the evening/night does it have these random spikes. At its worst, the average was 200ms and the spikes were up to ~600ms every 5 pings or so. This didn't happen before the update to 2.5.1.8, but it also wasn't quarantine before I updated, so I can't tell if it is one or the other. However, during the day when the ping is not quite as bad, the number of deviced using the network is not substantially higher. Could people using their networks around me be that detrimental to my backhaul connection?
  • Has a factory reset and setup from scratch been performed since last FW update to see if your "odd pings" are still there?
    Is the RBS wireless or wired to the RBR?
    Please format your ping captures so they are better readable here in the forums. Kind hard to read all that. :smileyfrustrated:
    • bisu-fan's avatar
      bisu-fan
      Yeah sorry I don't know why it formatted like that. I copied into notepad++ before pasting it into the comment box, and I guess some of the \n weren't transferred over properly?
      My satellite is ~30 feet away from the base station and connected wirelessly (unfortunately).
      I factory reset my units after FW and I've done the setup, and the ping spikes still exist.
