RLymburner
Dec 16, 2018Aspirant
Odd ping spikes during online gaming (& streaming Netflix) with Orbi RBR50 - lag but no packet loss
My son's computer connects wireless to Orbi mesh 5G but he's having network trouble with online gaming. During games (CS Go/Rocket League/etc), he'll lag horribly which kills the experience. Router i...
Dec 17, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Can you try connecting his computer via wired LAN cable and test?
Is the computer connected to the router or a satellite?
- RLymburnerDec 18, 2018Aspirant
Bear with me, cursory knowledge of networking only.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?I'm not clear what the ISP modem is - the Verizon ONT is bolted to the wall downstairs and I couldn't discern a model number.
Orbi is on main floor 50-60 ft. from this PC - stairwell physically located between computer & router but no electronics. 2 satellites hooked up on different floors (above/below). WiFi adapter nothing special, cheap $20 from Amazon (https://www.amazon.com/gp/product/B01KZGZ2U6/ref=oh_aui_search_detailpage?ie=UTF8&psc=1) . I downloaded & reinstalled drivers, but the Windows 10 drivers haven't been updated in 2 years.
Regarding configuration, 2.4g is set to Auto-channel and its going to "9". Using an app I was able to detect pair of neighbors using channels 1 and 6. On 5g, the channel is set to 48 and shows "36+40+44+48(P)". Security setting is WPA2-PSK [AES]
Router firmware is V2.2.1.210 and son's computer connects to the router, not the satellites.When I connect his PC via cable, the lag disappears and ping is consistent 4-5ms and he's happily gaming again.
I have not done these steps yet. Tough to spend too much time troubleshooting with the family around & Christmas looming! Give me another day or two to report.Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001- FURRYe38Dec 18, 2018Guru - Experienced User
Try setting 2.4Ghz to channel 11. 9 is a sub channel and not a primary channel.
Try some of the suggestion when you get time.
