GeoV
Dec 19, 2020Tutor
Offline with Orbi RBR40 but still have very slow internet
The Orbi worked great for about 6-7 months, but lately nothing but problems. First the satellites kept disconnecting. Finally, I started from scratch by resetting everything to new. Now the satellite...
Dec 19, 2020Guru - Experienced User
Power OFF the ISP Modem for 30 seconds then back on?
Where is it showeing off line? RBRs web page or Orbi app?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Not sure what getting on social media will do for you.
- GeoVDec 22, 2020Tutor
Social media will help me tell others the poor support you get from Orbi and they do not last long.
FURRYe38 wrote:What Firmware version is currently loaded?
Power OFF the ISP Modem for 30 seconds then back on?Where is it showeing off line? RBRs web page or Orbi app?
https://kb.netgear.com/19668/Link-Rate-and-Transfer-SpeedTry enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026Not sure what getting on social media will do for you.
- FURRYe38Dec 22, 2020Guru - Experienced User
Though some may catagorize this forum as social media, it's actually a tech support forum. Experienced users are here to help those user with problems and questions as best as we can. We volunteer here on our own accord. Were not employees. It's completely up to users to take advise from users here in the forums or not. If users choose NOT to then thats up to users. NG offers more direct online and phone support for those that have it available to them.
We've found that support here in the forums lasts longer than email or phone support. However, forum support is not unlimited. We can only help and troubleshoot to a point. If and when thats all exhausted, then users have to contact NG support to continue the pursuit of a resolution as if the problem is a hard ware problem, or there is a user account problem, then the forums can't help with that and needs to be addressed by NG support.Social media should not be used for technical support issues IMO. Tech support forums are for that and do work. Users have to be willing to listen and take the advise and suggestions and work with forum users to come to a solution for there problems which MOST of the time, happens here in the forums.
"Can lead a horse to water, can't make it drink!"
Good Luck in your endeavours and have a nice day. :smileyvery-happy:
I might be the horse, but the lack of support is a jackass. I have done what has been stated in this chat numerous times. I read other posts and tried different things before I decided to get into the community. I am in the technical field, particularly broadcast over IP, so I am not necessarily that handicap.
FURRYe38 wrote:Though some may catagorize this forum as social media, it's actually a tech support forum. Experienced users are here to help those user with problems and questions as best as we can. We volunteer here on our own accord. Were not employees. It's completely up to users to take advise from users here in the forums or not. If users choose NOT to then thats up to users. NG offers more direct online and phone support for those that have it available to them.
