Retired_Member
Mar 14, 2020Old, disconnected Orbi satellite continues to show up green on my orbi app/network map
'Orbi"My oldi disconnected Orbi-voice satellite still shows up on the "Orbi neatgear" app under "network map". It shows up green, has not been powered up in months, the details say it's off line. T...
CrimpOn
Mar 14, 2020Guru - Experienced User
Retired_Member wrote:I can not find a way to remove the old dissconnected Satellie. The fatc that it's showing up green is causing intermittant issues.
The "app" remains a mystery to me. On the Orbi web interface, removing a satellite is simple. On the "Attached Devices" web page, just click on the satellite in question, which will indicate as "Disconnected". A pop-up window will appear asking if you want to remove the satellite. Click, and it's done.
- Retired_MemberMar 14, 2020
Thank you, Thank you so very much.
Yes via thier web site I was able to delete the errouneous satellite.
You were a big help!
I owe you dinner lol
Thanks and stay safe
Mitch
