nenaang's avatar
nenaang
Old Encryption Error
Hello all,
I had a family member connect today and they told me that their ASUS gave them a warning about old encryption. I’ve searched everywhere and do not see this mentioned. Any idea what’s causing this? Firmware is updated. Any help would be appreciated.
  • You should be able to update to v2.5.1.8 directly on the RBS first then RBR lastly.
    https://www.netgear.com/support/product/RBK50.aspx#download
    Download the .zip files for each RBS and RBR. Unpack the .zip file to reveal the .img files. Use IE11, Firefox or Opera web browser on a wire connected PC to send the .img files manually.
    Once you get the RBS and RBR updated, factory reset both units and setup from scratch.
    nenaang wrote:
    Firmware version: v2.3.5.30
    Asus T100 (tablet)
    WPA2-PSK
  • FURRYe38's avatar
    What Firmware is currently loaded? Be sepecific please...
    What ASUS device is this? Wireless device?
    What security modes are you using on your Orbi system? WPA or WPA2?
    • nenaang's avatar
      nenaang
      Asus T100 (tablet)
      WPA2-PSK
      • FURRYe38's avatar
        This the only device that shows this?
        Ensure the Asus devices firmware or software is updated as well.
