paulcotecaller
Apr 08, 2020Follower
Old Man Trying To Re-Connect My Orbi After Changing From AT&T To Xfinity
My Orbi and it's two satellites have not worked since I changed from AT&T to Xfinity. I've followed all of the suggestions on re-connecting that I have found. I get as far as the reconnection screen....
Apr 08, 2020Guru - Experienced User
Built in router at the modem by chance>? if so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Retired_MemberApr 08, 2020
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopthis type of response is why some people walk away more confused. You ask what type of modem the person has and without waiting on a response you start talking about a double NAT. Crazy. Not to mention you assume everyone knows what a double NAT is.
here put these shoes on and take a walk
