ahi's avatar
ahi
Follower
Nov 07, 2017
old network keeps on connecting
Hi
My devices are always keeps connecting  to the old network.
how can I cancel that as I heard there is a solution  for that
be  aware I am a tech dummy... so please no complicated terms
many thanks J
  • You need to turn the wifi OFF on the equipment the old wifi network is coming from.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    You may also want to check your devices to forget or remove the old network as a preferred network to connect to.
