pushpinder
Apr 01, 2020Aspirant
One laptop connects to internet when connected to 2 satelites but not from router
One laptop is not able to get on internet when connected to router RBR50 but when connected to 2 satelites(RBS50 and RBS20), internet works like a charm. Problem is with one windows 10 laptop only wh...
pushpinder
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too? Hitron CODA-4582
Is the Orbi system operating in Router or AP mode? Working in router mode
Laptop wifi adapters are upto date. It is a ASUS Zenbook running windows 10. Don't have any connection issues with any other network at school or other place. It doesn't work when connected to router but works when connected to satelite so not able to conclusively determine if problem is totally with laptop.
Apr 01, 2020Guru - Experienced User
Turn OFF the RBSs.
Configure the RBRs wifi security to disable temporarily. Try to connect the laptop to the RBR. Does it connect at all? Re-enable WPA2 and AES only.
Your modem has a router and wifi built in:
http://www.hitron-americas.com/product/coda-4582/
What mode is it working in? Router or is it bridged? Bridged would be preferred.
