bozhaobo
Nov 30, 2020Aspirant
One of 2 RBS20 satellite disconnect randomly
I have RBR20 + 2 RBS20 setup, with firmware v2.5.1.16 on all of them. the system works fine since July 2020, but suddenly one of the satellite randomly disconnect/offine multiple time a day. I tried ...
Nov 30, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Try swapping RBS locations?
- bozhaoboDec 01, 2020Aspirant
Thanks for the reply!
I swapped RBS locations and then move one to a higher spot and this time it worked - so far so good. Not sure why the location worked for the past 5 months and suddently not working but hope this time will last longer.
- FURRYe38Dec 01, 2020Guru - Experienced User
Maybe some sort of new interferences or noise.
Mark your thread as solved so others will know.
Enjoy.
