printgeek
Jul 09, 2020Aspirant
One of my RBS50 on ethernet backhual has flaky connection
 I have an RBR50 and 2 RBS50 satellites that are connected via ethernet backhual directly to the RBR50. The RBR50 is in AP mode and connected to a gigabit router which is getting internet and DHCP via...
- Jul 09, 2020
Download the FW file for the RBS50 and log in to the Orbi2 web page at 192.168.2.116 and manually apply the FW update there.
Get the file from here:
Jul 09, 2020Guru - Experienced User
Manually download FW file for the RBS and use the RBS web page to apply the FW update if the FW is out of sync or not the same as on the other units.
printgeek
When I click the manual update button the only device that shows is the satellite that is already working. See attached screenshots
- FURRYe38Jul 09, 2020Guru - Experienced User
