omolko
Oct 16, 2022Aspirant
one of my satellite RBK 50 has lost sync
Hello I don't find any issue to this trouble. firmware V2.7.3.22 I have reset every thing, put the satellite near the router, link them with an ethernet cable... when I try to sync, the satellite...
omolko
thanks for your answer.
My orbi app says that my firmware is up to date...
Of course I try to link it again wireless without success. I have a second rbs satellite which is linking without trouble
KevinLiT
Oct 17, 2022NETGEAR Moderator
Hello omolko,
Welcome to the NETGEAR Community!
Thank you for your post!
I understand that you are having difficulties syncing your RBS50 to your RBR50. Please factory reset your RBS50 then sync the satellite to your RBR50.
Best,
Kevin
Community Team
- omolkoOct 17, 2022Aspirant
thanks for your help. I have done this several times without success.
- CrimpOnOct 17, 2022Guru - Experienced User
Please excuse if I have misread the situation....
After a satellite has been Factory Reset, it must be "Added" to the Orbi router again. What this sounds like (to me) is the satellite is working perfectly fine. It starts up, has no idea what router that it should connect to, and turns magenta out of frustration. The router may remember "This satellite isn't connected any more. Wonder when it is going to show up again?", but the satellite does not know which router to use.
How about opening the Orbi web browser interface, Attached Devices page, Delete that satellite.
Then go back to the main menu and "Add Orbi Satellite".
(or, I am not having a good day. Sorry)
- KevinLiTOct 18, 2022NETGEAR Moderator
Hello omolko,
Please use the WebGUI (orbilogin.com) to establish connections between the router and satellite by navigating to the following:
BASIC Home> Add Orbi Satellite> Then follow the prompts.
Please let me know if this solved your issue!
Best,
Kevin
Community Team
- omolkoOct 31, 2022Aspirant
Hi
no my satellite is still blinking (white)
