Bremster
Mar 15, 2019Aspirant
One Orbi router RBR20 in the same house with one cable provider modem, 2 wifi networks
Bremster
Connected a ORBI routerRBR20 via a ethernet cable from the cable companies modem to a remote masterbedroom (large house) the remainder of the house has wifi from cable supplier modem. This creates problems, with wireless printer (location signal too weak from ORBI). I think I have to get another satalite unless someone has another suggestion. I have a ethernet outlet close to the printer, I could use another Netgear access point EX6150 (I have one) device to create wifi network that would be the same as the rest of house.
Anyone care to weigh in?
- CrimpOnMar 15, 2019Guru - Experienced User
Ordinarily, people do not purchase a "mesh system" and have only a single device (the base router). Sort of defeats the purpose of investing in mesh. The goal is usually to have a single Wi-Fi network spanning the entire house. Not that what you are doing is wrong, just unusual.
It is not clear from the description whether the wireless printer gets a good Wi-Fi connection from the cable company modem Wi-Fi.
It would also be useful to know if your Orbi is running in "router" or "Access Point" mode.
