Bremster
Mar 15, 2019Aspirant
One Orbi router RBR20 in the same house with one cable provider modem, 2 wifi networks
Bremster
Connected a ORBI routerRBR20 via a ethernet cable from the cable companies modem to a remote masterbedroom (large house) the remainder of the house has wifi from cable supplier modem. This creates problems, with wireless printer (location signal too weak from ORBI). I think I have to get another satalite unless someone has another suggestion. I have a ethernet outlet close to the printer, I could use another Netgear access point EX6150 (I have one) device to create wifi network that would be the same as the rest of house.
Anyone care to weigh in?
CrimpOn
Mar 15, 2019Guru - Experienced User
Ordinarily, people do not purchase a "mesh system" and have only a single device (the base router). Sort of defeats the purpose of investing in mesh. The goal is usually to have a single Wi-Fi network spanning the entire house. Not that what you are doing is wrong, just unusual.
It is not clear from the description whether the wireless printer gets a good Wi-Fi connection from the cable company modem Wi-Fi.
It would also be useful to know if your Orbi is running in "router" or "Access Point" mode.
