greg0422
Sep 09, 2018Aspirant
One satellite keeps losing connection
Firmware V2.1.4.16
I have three satellites. The main router is downstairs with one satellite. The other two are upstairs.
The satellites upstairs are much further from the router, but never h...
Sep 10, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Try swapping the satellite around with another one in a different area to see if the problem follows or not...
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- greg0422Sep 10, 2018Aspirant
Thanks I'll try this and give results. It might take a while to reply again because we're going out of town for a couple weeks soon.
The house is 3500 sq ft. The router is in my wife's office which is about 40 feet from the satellite. We really cannot place the router closer to the the middle of the house because she works from home and needs the main connection in her office. Right now the signal from the router to the sattelite must go across our entryway, through the dining room and then across the kitchen. There are no kitchen appliances directly in the path between the two.
The upstairs satellites are similar distances now that I think about it, if you angle through the floor. One of them is probably closer.
I tried enabling beamforming but that didn't make much difference. It currently has MU-MIMO, Fast Roaming, and Daisy-Chain. IPv6 is already disabled. I don't have a setting for coexistence to 40 MHz only.
