Deog
Feb 03, 2025Follower
OneDrive connection failed through Orbi RBR50
Hi All,
I'm using Orbi RBR50 and 2 satellites for years for my domestic wifi network and was very satisfied of it.
Using OneDrive on PCs, tablets and mobiles, I recently discover that the OneDrive sync didn't come up anymore when I use my Orbi network (OneDrive web interface or desktop client or Apps on tab or mobile). OneDrive can't connect anymore.
- It works fine when I'm connected elsewhere.
- It works fine even when I'm connected on the embedded wifi of my Internet provider's box (Orbi router is behind).
-> then it's Orbi related.
What can I do ?
Thanks in advance !!
1 Reply
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...Try disabling the following and see:
Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter.Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
