pablohoney
Jul 25, 2019Luminary
Ongoing Issues/bugs with Orbi RBK/RBS 50
I think this needs a constant/ongoing thread as every-time the “geniuses” at Netgear update the firmware version it breaks something in the setup. Nothing has changed in my setup or previous settin...
Retired_Member
Jul 26, 2019are you doing 'auto' or 'manual' updates?
pablohoney
Jul 26, 2019Luminary
It should not matter if it was auto or manually updated now should it? It was a manual update.
- Retired_MemberJul 26, 2019
it does in your case.
the question becomes why did you perform a update?
after years of listening to people whine about the forced updates, NG apparently changed their policy to where the only updates that are pushed (auto) are those with major changes. All others may not be required. This follows the line of thought..."if it's working, leave it alone".
have fun!
- docktahdandbJul 26, 2019Guide
Well maybe people wouldn't whine about the updates if they weren't being delivered crap, you NG cuck.
