masonworld
Dec 30, 2017Apprentice
Ongoing WiFi problems with Orbi and Apple -- About to pull the plug
I'm at my kitchen table writing this from my laptop connected to my cell phone hotspot because Orbi kicked me off the network again. I am at my wits end. Moving from the Nighthawk R7000 to the Orbi...
guzzijason
Do you run the Orbi in AP or router mode? In AP mode, clients get their DHCP address from an upstream server/router, but in router mode, the DHCP responses comes directly from the Orbi.
Mine is is router mode - I've not had any problems with DHCP so far with Mac, iOS, or Windows clients.
- masonworldDec 30, 2017Apprentice
Should have mentioned that -- I am in router mode.
Looks like I am having problems very similar to those in another thread that seem to be the result of Orbi firmware v2.1.1.16
- guzzijasonDec 30, 2017Apprentice
Ah, yes. I'm on V2.0.0.76 and have (hopefully) disabled auto-updates. You might want to consider downgrading for the time being and see if that helps.
- masonworldDec 30, 2017ApprenticeI’m actually thinking about going the other direction and upgrading to Linksys
