masonworld
Dec 30, 2017Apprentice
Ongoing WiFi problems with Orbi and Apple -- About to pull the plug
I'm at my kitchen table writing this from my laptop connected to my cell phone hotspot because Orbi kicked me off the network again. I am at my wits end. Moving from the Nighthawk R7000 to the Orbi...
aaz
Dec 31, 2017Virtuoso
DudeDad wrote:I had an issue with my MacBook pros not responding, having to turn wifi off/on to solve it. I did an online chat with NetGear and here’s what worked:
Unfortunately, netgear is still using the same script for every problem. This is the same chat I had with them months back when I updated to a V 1.x firmware at that time that was producing disconnects all the time. I ended up turning off UPNP which actually solved the problem after noticing UPNP connection issues preceeding the disconnects.
None of these suggestions actually dealt directly with your issue. I've had stability on 2.1.1.16 for about a week before I noticed some of my devices where not getting internet though they were connected on Wifi. After a router reboot they will work again for another week I suspect. I do think netgear really messed up something in this latest firmware and I am hoping they come out with an update that really overhauls this.
Worth noting that I did not have this disconnect issue at 2.0.0.74. So at this point I think I'll just reboot once a week and wait for the update.
masonworld
Dec 31, 2017Apprentice
Yep -- I did not want to be negative or imply that I did not appreciate DudeDad's reply -- I really do. But all of this "change the channel generic india call center script stuff" is clearly not going to solve whatever underlying problem Netgear has with this router.
I did get a good laugh out of the MTU stuff....took me back to the good old days of PPPOE and RS232.
It's really a bummer -- I like netgear and have recommended them so many times. I hope their management will see their way clear to give the Orbi team the needed resources to address this quickly.
- DudeDadJan 01, 2018Apprentice
I had the issue before updating to the current firmware. I tried what they suggested, and have not had any issues with MacBook Pro disconnection. I then upgraded to the latest firmware (not my choice, of course) and have not had any problems other than improper reporting of which Orbi units (router or 2 satellites) are assigned to the various devices (30+). I shared what I experienced to see if it would help anyone else -- certainly easy to try without any risk. Whether it's the "script" or not, my connectivity issue went away. Whether it was the advice given or sheer coincidence, I'm not complaining.
...and for the record, I'm not defending Netgear with it's firmware upgrades. Personally, I think that the user should be able to choose between manual or auto updates. I do think that some of the issues have to do with each individual set up, and no update is perfect. I see Mac OS X and Windows complaints during updates -- problems I've never had. Perhaps the world of Orbi users is larger than the world of posters on this forum. I know that no software update is without issues, regardless of company. What does matter is how fast a company responds to problems and addresses them. From the comments here (and I'm new to Orbi, about a month in), Netgear needs work in that regard.
Happy new year....may your connections never drop
- masonworldJan 01, 2018ApprenticeRight. Exactly why I didn’t reply negatively at first. I’m very happy it worked for you. Thanks again for taking the time to reply. Happy New Year.
