sboi
Jun 02, 2020Initiate
Online Firmware Update 2.3.5.30
I tried to update firmware for hte Orbi RBR50 and RBS50 today via the online tool. As noted in the easy to follow instructions, available firmware came up for both (V2.3.5.30) and I hit Update all bu...
- Jun 03, 2020
got it; It appears the web page just wouldn't refresh from "updating" I logged in from a different page and things were stated as "up to date"
Thanks for the tips, much appreciated.
Jun 03, 2020Guru - Experienced User
Try a factory reset as last resort...
sboi wrote:I tried to update firmware for hte Orbi RBR50 and RBS50 today via the online tool. As noted in the easy to follow instructions, available firmware came up for both (V2.3.5.30) and I hit Update all button. The RBS50 updated within 2 min, but the RBR50 has been in "updating" mode for nearly an hour. Is this normal? If it doesn't switch to off, will the firmware not work?
- sboiJun 03, 2020Initiate
- FURRYe38Jun 03, 2020Guru - Experienced User
Be sure to make a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. :smileywink:
