JesRas
Jan 20, 2020Aspirant
Only 20MHz in 5GHz band works for Intel Wireless-AC 9560 with Orbi RBK50
Orbi RBR50, Firmware V2.3.5.30 Acer Aspire Windows 10 64 bit updated 20.01.20 with Intel AC 9560 160MHz, Driver 21.60.2.1 (date15.12.19) but problem exists same what driver I use Connect t...
- Jan 23, 2020
Thanx for your engagement. After days of help from Intel, they asked my to take the PC to the dealer to get it fixed.
Jan 20, 2020Guru - Experienced User
Orbi doesn't support 160Mhz channel width on it's 1st 5Ghz radio. It is supported on it's 2nd 5Ghz radio, however that is ONLY for the wireless backhaul channel between the RBR and RBS. This is not usable by any connected client deivce nor configurable by a user.
Any 5Ghz devices should support and connect at 866Mbps on the 1st 5Ghz radio at 40Mhz channel width. If the adapter is not connecting at this rate, the adapter maybe faulty or mis-configured. I would try a different non intel adapter in the PC to see if the problem continues or not.
Also update FW to v2.5.1.8 as well on the entire system. A factory reset and setup from scratch would be recommended after the FW update.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- JesRasJan 20, 2020AspirantThanx
Tried to update firmware but got the “incorrect firmware” message.
I will look into the other ideas tomorrow.- CrimpOnJan 20, 2020Guru - Experienced User
I know this is totally "off the wall", but the thought that an Intel WiFi adapter will not connect to a Netgear router is pretty difficult to accept.
Am I correct that the problem is "no internet", not "no connection"?
There have been a number of instances reported where the Orbi Access Control gets turned on and new devices are "Denied access to internet." On the Orbi web interface, what does it say about the Acer computer when it is connected to Orbi? (Hint: does the word "Blocked" appear in red?)
If this is the case, I would navigate to the Advanced Tab, Security, Access Control. First, I would uncheck Access Control (turn it off) and click on "Apply". If you want to use Access Control, then this specific WiFi adapter has to be put into the "Allowed" table.
Whether Orbi or Acer does or does not support a specific bandwidth should be immaterial. WiFi adapters follow standards, and the standards are nearly always "backward compatible." When set to "Auto", the adapter should negotiate with Orbi and connect at the setting that is best.
- JesRasJan 20, 2020AspirantConnected with 144Mbps. 5G now. Getting 100mps download. It used to be 500.
With my other laptop I get 500 mbps.
Sometimes i Get error messages from my network card. Always when set to “auto”.
I can try all you suggestions, but I think my intel card is damaged.
