JesRas
Jan 20, 2020Aspirant
Only 20MHz in 5GHz band works for Intel Wireless-AC 9560 with Orbi RBK50
Orbi RBR50, Firmware V2.3.5.30 Acer Aspire Windows 10 64 bit updated 20.01.20 with Intel AC 9560 160MHz, Driver 21.60.2.1 (date15.12.19) but problem exists same what driver I use Connect t...
- Jan 23, 2020
Thanx for your engagement. After days of help from Intel, they asked my to take the PC to the dealer to get it fixed.
CrimpOn
Jan 20, 2020Guru - Experienced User
JesRas wrote:
Connected with 144Mbps. 5G now. Getting 100mps download. It used to be 500.
I can try all you suggestions, but I think my intel card is damaged.
I am trying to reconcile. (1) this card worked at a friend's house, (2) the card is now connected and gets 100mps download, (3) the intel card is damaged.
What happened between it would connect but got no internet, and now when it connects and has internet?
JesRas
Jan 21, 2020Aspirant
Toggling with settings. «Automatic» vs «20MHz» in the 5GHz channel width settings.
IT works only when set to 20MHz.
Sometimes it seams to connect to Orbi on “automatic” but no data passes. Link rate in Orbi = N/A
My other pc with Intel AC 8265 works in both modes and full speed.
