JesRas
Jan 20, 2020Aspirant
Only 20MHz in 5GHz band works for Intel Wireless-AC 9560 with Orbi RBK50
Orbi RBR50, Firmware V2.3.5.30 Acer Aspire Windows 10 64 bit updated 20.01.20 with Intel AC 9560 160MHz, Driver 21.60.2.1 (date15.12.19) but problem exists same what driver I use Connect t...
- Jan 23, 2020
Thanx for your engagement. After days of help from Intel, they asked my to take the PC to the dealer to get it fixed.
Jan 21, 2020Guru - Experienced User
If your other laptop gets to spec speeds and this one with the Intel card installed does, I would presume this one Intel card is faulty and needs to be replaced.
JesRas wrote:
Connected with 144Mbps. 5G now. Getting 100mps download. It used to be 500.
With my other laptop I get 500 mbps.
Sometimes i Get error messages from my network card. Always when set to “auto”.
I can try all you suggestions, but I think my intel card is damaged.
