Retro__Arcade
Jan 20, 2022Aspirant
Only getting 40 Mb/s WiFi with Orbi RBR40
I am currently using the Orbi AC2200 Tri-band WiFi Router (RBR40) with a xFi Gateway 3rd Generation Modem/Router (I have the Gateway in bridgemode so that the router function is turned off). My curr...
Jan 20, 2022Guru - Experienced User
one thing to check is if you're testing over 2.4ghz or 5ghz.
2.4ghz is a much slower network and sensitive to interference.
5ghz is significantly faster
