Retro__Arcade
Jan 20, 2022Aspirant
Only getting 40 Mb/s WiFi with Orbi RBR40
I am currently using the Orbi AC2200 Tri-band WiFi Router (RBR40) with a xFi Gateway 3rd Generation Modem/Router (I have the Gateway in bridgemode so that the router function is turned off). My curr...
Jan 20, 2022Guru - Experienced User
one thing to check is if you're testing over 2.4ghz or 5ghz.
2.4ghz is a much slower network and sensitive to interference.
5ghz is significantly faster
Retro__Arcade
I checked that right off the bat. I am getting 40 Mb/s over 5 ghz.
- plemansJan 20, 2022Guru - Experienced User
What firmware is on the router and the satellites?
If you hardwire into the satellites and test their speed, what do you get?
- Retro__ArcadeJan 20, 2022Aspirant
Firmware Version: v2.7.3.22
I can't currently test the satellite wired speeds because I only have one wired device and at the moment I need it plugged in to the main Orbi router. Sorry.
then power off the satellites and test what speed you get when only the router is connected.
You can also try factory resetting the router/satellites.
