Retro__Arcade
Jan 20, 2022Aspirant
Only getting 40 Mb/s WiFi with Orbi RBR40
I am currently using the Orbi AC2200 Tri-band WiFi Router (RBR40) with a xFi Gateway 3rd Generation Modem/Router (I have the Gateway in bridgemode so that the router function is turned off). My curr...
Retro__Arcade
I checked that right off the bat. I am getting 40 Mb/s over 5 ghz.
Jan 20, 2022Guru - Experienced User
What firmware is on the router and the satellites?
If you hardwire into the satellites and test their speed, what do you get?
- Retro__ArcadeJan 20, 2022Aspirant
Firmware Version: v2.7.3.22
I can't currently test the satellite wired speeds because I only have one wired device and at the moment I need it plugged in to the main Orbi router. Sorry.
- plemansJan 20, 2022Guru - Experienced User
then power off the satellites and test what speed you get when only the router is connected.
You can also try factory resetting the router/satellites.
Ok, I will try testing my Orbi with the satellites powered off this evening. I did a full factory reset last night and it didn't help.
