CR-sound
Jun 02, 2021Aspirant
Only some devices with DNS problems
This may be a little different than the current DNS issues discussed...or maybe not. Most of my devices are connecting with no problem (3 Windows 10 computers, a Windows 2012 Server , 4 android phone...
- Jun 02, 2021
What mode is your modem working in? Router or Bridge?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopYou can manully update FW to the RBW if it needs to be udpated.
CR-sound
Checked from the desktop access. I have 2 RBS 50s and an RBS50Y (outdoor satellite) with no firmware updates required. The RBR50 shows no firmware update available. The RBW30 satellite has current firmware of v.2.5.0.4 and shows update failed. The units I was unable to get DNS on were connecting via an RBS50 trying both wifi and ethernet.
BTW: the units with the DNS issues connect to the local network and server domain with no problem.
I have not recyled the Comcast router; they list it as Technicolor CGM4140COM.
RBR50 settings include allowing new devices to connect.
Jun 02, 2021Guru - Experienced User
Couple of options,
- CR-soundJun 25, 2021Aspirant
I ended up setting the Orbi in Access Point Mode...The Comcast/Xfinity modem is designed, it seems , to be really hard to tweak.
Seems OK now. Thanks!
- FURRYe38Jun 25, 2021Guru - Experienced User
Enjoy. :smileywink:
