CR-sound
Jun 02, 2021Aspirant
Only some devices with DNS problems
This may be a little different than the current DNS issues discussed...or maybe not. Most of my devices are connecting with no problem (3 Windows 10 computers, a Windows 2012 Server , 4 android phone...
- Jun 02, 2021
What mode is your modem working in? Router or Bridge?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopYou can manully update FW to the RBW if it needs to be udpated.
CrimpOn
Jun 02, 2021Guru - Experienced User
CR-sound wrote:Yesterday, I turned on 4 Windows machines that had been on the network before, but were off. They would not connect, DNS server not responding.
You've probably already checked, but:
- These 4 Windows computers were on the Orbi network previously?
- Their IPv4 properties say to get IP address, subnet mask, gateway, and DNS server using DHCP?
- What does the command ipconfig /all report for the ethernet and the WiFi interfaces?
(obviously one at a time, depending on how they are connected.)
