Stallions2009
Aug 31, 2022Aspirant
Ooredoo Orbi
Hi all, Simple Can I change the software of Ooredoo and upload the original software of the company. As I bought it from Ooredoo Qatar and took it to Egypt but I can’t set it up on my ISP config...
ekhalil
Sep 01, 2022Master
I don’t think you will be able to use the original Netgear Orbi firmware, but probably you can use one of the custom-made firmware images like Voxel and others.
- Stallions2009Sep 01, 2022AspirantMy orbi model is RBR50
How can I get the Voxl Image and how can I use it- ekhalilSep 18, 2022MasterPlease check this out: https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1896167#M89080
