Stallions2009
Aug 31, 2022Aspirant
Ooredoo Orbi
Hi all, Simple Can I change the software of Ooredoo and upload the original software of the company. As I bought it from Ooredoo Qatar and took it to Egypt but I can’t set it up on my ISP config...
Tryingtohelp
Oct 03, 2022Initiate
Yes you can update your router to the Netgear stock firmware. It worked for me. Just download the latest firmware for the RBR50 from Netgear downloads site and follow instructions in their page about uploading the firmware using a TFTP client:
https://kb.netgear.com/000059633/How-do-I-upload-firmware-to-my-NETGEAR-router-using-a-TFTP-client-on-Microsoft-Windows
One thing not mentioned in the description above is how to put the router into recovery mode. You need to press the reset button while powering on the router and keep pressing it few seconds after the orange /red light next to it keeps flashing. That will keep the router in recovery mode so you can then send the firmware file from your computer by clicking "Put" in the TFTP software.
You can use the same method to update the satellite using its corresponding firmware.
When done your router will be unlocked for use with any network you wish to use.
