einbecker
Mar 23, 2024Aspirant
Open DNS Resolver on IPv6
All, I am using an Orbi AC3000 RBR50, with latest firmware (V2.7.4.2), as my router. I am on a Vodafone Cable network in Germany/NRW, and the cable modem is set to bridge mode, so the router is d...
einbecker
Sorry, somehow the update feature of the Orbi did not know that there was a newer firmware. Updated to latest firmware (V2.7.5.4) but still the same issue (with dig from server of the internet, there clearly is an Open DNS resolver at the IPv6 address of the Orbi router...)
CrimpOn
Mar 23, 2024Guru - Experienced User
It indeed comes as a surprise to owners of the RBR50 router that the firmware released in Feb, 2023 is not yet detected by the Firmware Update feature of the router/app.
This is indeed a puzzle. One would think that every Netgear router in the world would exhibit the same behavior. That they do not seems to indicate that there is something different about this particular router/network.
We know that the Orbi firewall ignores all IPv4 connection attempts, unless the user has specifically Forwarded ports to internal IPs.
IPv6 options are defined in the Orbi web access, Advanced Tab, Advanced Settings menu... IPv6.
My RBR50 options are:
- Connection Type: DHCP
- User Class: (Blank)
- Domain Name (Blank)
- Domain Name Servers are IPv6 versions of CloudFlare and Google
- LAN Setup Autoconfig
Enable RIPng (On) - IPv6Filtering (Open)
(I notice that the "Help" information for this screen does not mention the IPv6Filtering option or suggest why one would want it to be "Open" or "Secured"
