CJ1941
Jul 14, 2020Aspirant
Open DNS with Orbi ROuter
Hi - Just went from a Nighthawk router to the Orbi RB50. In the old router I forced the router to use the OpenDNS server and setup the same addresses with the Orbi router. But the Orbi doesn't ...
CJ1941
Jul 15, 2020Aspirant
I put in the corrent OpenDNS IP addresses in the Orbi web app, just like I did with the Nighthawk, but it doesn't work doing that. There's no OpenDNS filtering going on, so something is different with Orbi than Nighthawk and I don't know what's different that suddenly breaks what used to work just fine. Any thoughts?
CrimpOn
Jul 15, 2020Guru - Experienced User
You are waaaay ahead of me on OpenDNS.
How does OpenDNS know that you have an "account"?
Is it by IP address.... or?
