mlmdjd
Jun 26, 2020Tutor
Opening ports on Orbi for magic jack
I am having trouble with my Magic Jack phone device. I have done extensive troubleshooting with them as well as replacing devices, cords, etc. They keep telling me to make sure ports 5060-5070 are op...
Dec 31, 2020Guru - Experienced User
Any progress on this? Not sure if this could a Orbi issue or a MJ issue. DMZ should work will for any connection issues thru Orbi.
mlmdjd wrote:At first I thought it might have worked as a few phone calls were fine. However, it has not worked as the receiver of the phone calls hears a disrupted audio - voice goes in and out for them. It sounds fine from my end but not from the receiver.
mlmdjd
Jan 01, 2021Tutor
I just assumed this was a Magic Jack issue as I have no other problems with my Orbi router. My internet connection is good, reliable and dependable. Good speeds. Not sure what else I should be expecting if it was an Orbi problem. Thanks!
- FURRYe38Jan 02, 2021Guru - Experienced User
Probably. Good Luck.
