bwalder
Jan 21, 2021Aspirant
Opening Ports on Orbi Router
Having problems loading programs on PlayStation 4. This is their recommendation If the basic connection troubleshooting steps haven’t solved the issue, you may need to open (forward) the PSN ports ...
Jan 21, 2021Guru - Experienced User
Log into the RBRs web page and under Advanced Tab/Advanced settings you see Port Forwarding section.
- bwalderJan 21, 2021Aspirant
Router Firmware Version
V2.5.1.16Using Cox as provider through Arris model Model TM3402a
I've been on the ORBI website but the port forwarding is way above my pay scale. Have no idea how to do that.
Thanks for any guidance.
- CrimpOnJan 21, 2021Guru - Experienced User
bwalder wrote:Using Cox as provider through Arris model Model TM3402a
The "good news" is that the Arris TM3402a is "only a modem" and thus will not interfere with opening ports on the Orbi.
You will need the IP address of the PlayStation.
Log into the Orbi web interface (http://orbilogin.net) using the admin credentials: "admin" and the admin password, which is not the same as the WiFi password or the Netgear community login password.
Click on the "Advanced" Tab.
Click on Advanced Setup
Click on Port Forwarding/Port Triggering
Click on the "Add Custom Service" button.
Enter a name that you like (maybe PlayStation)
Fill in the the port range (3478-3480)
Select TCP/UDP
Fill in the IP address of the PlayStation or pick it from the list.
Click "Apply".
- bwalderJan 22, 2021Aspirant
Thank you so much for the easy to follow instructions. One question...it asks to select the service type. Do I choose port forwarding or port triggering?
Many thanks!
