jbasen's avatar
jbasen
OpenVPN Error: mbed TLS: SSL read errr : x509 with Orbi and iPhone App v3.0.1 (770)
I found several posts with this same problem but they were all related to the OpenVPN android app and the problem seemed to be fixed with an update to the App.  I'm having the same problem with the iPhone app when I try to connect to my Orbi.  Any assistance on how this can be solved would be greatly appreciated.
Thanks in advance for the help
  • jbasen
    Thank you for the information and thank you for mentioning that you replicated the issue on your wife's phone. I have sent you a message.
    ~Christian
    • jbasen's avatar
      jbasen
      Thanks Christian_R
      Unfortunately, I'm having the issue connecting to an Orbi RBR50.  It is good to know that it works with the Nighthawk R7800
      Thanks again
      • Christian_R's avatar
        Christian_R
        NETGEAR Employee Retired
        jbasen
        What firmware is your Orbi on? Have you tried reinstalling and installing the Orbi app?
        ~Christian
