jbasen
Sep 25, 2018Aspirant
OpenVPN Error: mbed TLS: SSL read errr : x509 with Orbi and iPhone App v3.0.1 (770)
I found several posts with this same problem but they were all related to the OpenVPN android app and the problem seemed to be fixed with an update to the App. I'm having the same problem with the i...
- Sep 26, 2018
Thank you for the information and thank you for mentioning that you replicated the issue on your wife's phone. I have sent you a message.
~Christian
Christian_R
Sep 26, 2018NETGEAR Employee Retired
What firmware is your Orbi on? Have you tried reinstalling and installing the Orbi app?
~Christian
jbasen
Sep 26, 2018Aspirant
Thanks Christian_R
My Orbi router and satellite are both on firmware V2.1.4.16, which I believe is the latest. The Orbi app is working fine for me. The problem occurs when I use the OpenVPN app to create a VPN tunnel over the Internet to my local, home network. OpenVPN is the app that is supported by Netgear for createing a secure tunnel to an Orbi router. I'm not sure if there is support for other client VPN apps with your Nighthawk router. This has been a problem for a while for me that I have been ignoring until now. I first noticed the problem with the prior version of the OpenVPN iPhone app and the problem persists with the latest release. I have not yet tried reinstalling the OpenVPN app.
Thanks again for your help
- jbasenSep 26, 2018Aspirant
I forgot to mention that I have duplicated the exact same problem with my wife's iphone
Thanks
- Christian_RSep 26, 2018NETGEAR Employee Retired
~Christian
