vphagura
Sep 20, 2019Tutor
OpenVPN on Android phone timeouts with Orbi
I have enabled VPN Service on my Orbi as directed on the Orbi manual and downloaded the OpenVPN profile for Smart phone. Which I imported on my Android phone but my phone does not connect to the VPN ...
- Sep 23, 2019
There is no other NAT device - being carrier grade NAT (by your ISP) or another router between the Orbi and the ISP connection?
Compare the Internet/WAN IP address from the Orbi dashbord with the IP when asking Dr. Google what is my ip addess - if this is not the same, figure...
vphagura
Sep 23, 2019Tutor
Thank you for your response. It at least confirms that I'm on the right path. But still no success on Android.
BTW my Android version is 9.0 on my Samsung Note 8.
CrimpOn
Sep 23, 2019Guru - Experienced User
I just tested my OpenVPN on my Sony Xperia on Android 9. As I recall, I had some difficulty importing the OVPN config file and putting it in the correct place for OpenVPN to find it. I definitely use the bottom of the three connection options: "OVPN Profile".
- vphaguraSep 23, 2019Tutor
Thank you again.
Yes, I have used the OVPN Profile option on the OpenVPN to put the profile in place that I got from Orbi. Also, I can see in the logs that it is trying to connect to my DDNS and IP correctly but fails and timesout. Could not get further than that. I may be doing something wrong somewhere.
- CrimpOnSep 23, 2019Guru - Experienced User
I also got myself into a mess when I created the DDNS entry and did not realize that ".mynetgear.com" was going to get added to my host name. (or was it the other way around?)
Interesting... I do not see that in my case.
I see in the OpenVPN logs that it trys to connect to the correct DDNS and IP.
