famousdavis
Aug 19, 2018Tutor
OpenVPN warning: No server certificate verification method has been enabled
Hi, I've got a new Orbi router (Model RBR20) and two satellites. The router's firmware is V2.1.4.16. I enabled OpenVPN on the Orbi router and it works fine with my mobile device. When I use OpenVP...
- Mar 02, 2019
try adding
remote-cert-tls server
to the end of your config file that should remove the warning
Christian_R
Aug 20, 2018NETGEAR Employee Retired
Hello famousdavis,
Thank you for reaching out to the community. I have passed this information along to our engineering team to look into. In the meantime, I would suggest upgrading your firmware to the latest version provided in the link below.
https://www.netgear.com/support/product/rbr20.aspx#RBR20%20Firmware%20Version%202.2.0.68
Best regards,
Christian
