famousdavis
Aug 19, 2018Tutor
OpenVPN warning: No server certificate verification method has been enabled
Hi, I've got a new Orbi router (Model RBR20) and two satellites. The router's firmware is V2.1.4.16. I enabled OpenVPN on the Orbi router and it works fine with my mobile device. When I use OpenVP...
- Mar 02, 2019
try adding
remote-cert-tls server
to the end of your config file that should remove the warning
famousdavis
Aug 20, 2018Tutor
Thanks, Christian.
When the Orbi router does it auto-check for new firmware, it says it’s already up-to-date (on V2.1.4.16).
Any downside to upgrading the firmware using your provided link? If I wanted to downgrade the firmware back to 2.1.4.16 (if something is screwy with the newer firmware version), is that possible?
And this wouldn’t require updating the firmware on the two satellites, would it?
Aug 20, 2018Guru - Experienced User
It's recommended to manually download the FW files and then update the Satellites first, then the router. Please use a wired LAN cable connected PC or laptop for this operation.
