famousdavis
Aug 19, 2018Tutor
OpenVPN warning: No server certificate verification method has been enabled
Hi, I've got a new Orbi router (Model RBR20) and two satellites. The router's firmware is V2.1.4.16. I enabled OpenVPN on the Orbi router and it works fine with my mobile device. When I use OpenVP...
- Mar 02, 2019
try adding
remote-cert-tls server
to the end of your config file that should remove the warning
Aug 20, 2018Guru - Experienced User
There will be separate files for the router and satellites.
famousdavis
Aug 20, 2018Tutor
Just saw your reply, thx. Although, weirdly, on my iPhone and laptop, I can’t scroll down to see your full reply. ??? Not happening with other posts???
