famousdavis
Aug 19, 2018Tutor
OpenVPN warning: No server certificate verification method has been enabled
Hi, I've got a new Orbi router (Model RBR20) and two satellites. The router's firmware is V2.1.4.16. I enabled OpenVPN on the Orbi router and it works fine with my mobile device. When I use OpenVP...
- Mar 02, 2019
try adding
remote-cert-tls server
to the end of your config file that should remove the warning
d-One
Sep 17, 2018Aspirant
I have the same issue! Firmware is up to date. I have uninstalled and reinstalled the OpenVPN three times. I have re-downloaded the configuration files and replaced them three times. I spent an hour on the phone with Netgear support with no resolution! So what seems to be the problem Netgear??
- FURRYe38Sep 17, 2018Guru - Experienced User
- Christian_RSep 17, 2018NETGEAR Employee Retired
Thank you for reaching out to us with expressing a similar issue as others. I have sent you a message.
~Christian
- birdy99Sep 25, 2018Aspirant
Same Problem... Just with win10... on ios config works
- ryoung81Oct 04, 2018Aspirant
I'm also having this issue, I'm on firmware 2.2.1.210. Can anyone provide any insight into how I can fix the issue w/ Windows 10?
Works fine on Android. I've tried downgranding OVPN to the earlier stable release, but that didn't fix the problem either.
