famousdavis
Aug 19, 2018Tutor
OpenVPN warning: No server certificate verification method has been enabled
Hi, I've got a new Orbi router (Model RBR20) and two satellites. The router's firmware is V2.1.4.16. I enabled OpenVPN on the Orbi router and it works fine with my mobile device. When I use OpenVP...
- Mar 02, 2019
try adding
remote-cert-tls server
to the end of your config file that should remove the warning
d-One
Sep 17, 2018Aspirant
I have the same issue! Firmware is up to date. I have uninstalled and reinstalled the OpenVPN three times. I have re-downloaded the configuration files and replaced them three times. I spent an hour on the phone with Netgear support with no resolution! So what seems to be the problem Netgear??
Sep 17, 2018Guru - Experienced User
