famousdavis
Aug 19, 2018Tutor
OpenVPN warning: No server certificate verification method has been enabled
Hi, I've got a new Orbi router (Model RBR20) and two satellites. The router's firmware is V2.1.4.16. I enabled OpenVPN on the Orbi router and it works fine with my mobile device. When I use OpenVP...
- Mar 03, 2019
try adding
remote-cert-tls server
to the end of your config file that should remove the warning
famousdavis
Aug 28, 2018Tutor
Hi all,
My curiosity got the best of me, so tonight I upgraded the RBR20 router to the latest firmware, v2.2.0.68. After the firmware update successfully applied and my Internet connection restored, I disconnected my laptop from my home network and connected it to my mobile phone's hotspot, so I could establish an OpenVPN connection outside my home's network.
I connected to my hotspot fine, started OpenVPN just fine, but, alas, I get the same warning message: "No server certificate verification method has been enabled."
The latest router firmware doesn't resolve this issue. :(
Christian_R
Sep 17, 2018NETGEAR Employee Retired
