famousdavis
Aug 19, 2018Tutor
OpenVPN warning: No server certificate verification method has been enabled
Hi, I've got a new Orbi router (Model RBR20) and two satellites. The router's firmware is V2.1.4.16. I enabled OpenVPN on the Orbi router and it works fine with my mobile device. When I use OpenVP...
- Mar 02, 2019
try adding
remote-cert-tls server
to the end of your config file that should remove the warning
mjbcomputers
Oct 17, 2018Aspirant
Same issue here. I cant believe this does work when you spend 400 dollars for a router.
Oct 18, 2018Guru - Experienced User
- ryoung81Oct 18, 2018Aspirant
The help team here had me contacted by tech support. I got to an agent that didn't really have any knowledge of the issue and was limited to searching for the issue on the forums and suggesting to try the things that we've already done.
She said if I didn't want to factory reset the router, that she wouldn't be able to escalate the issue. Needless to say I'm not hard resetting my business router in the middle of the day.
It's what I get for using Netgear for something business critical....
- FURRYe38Oct 18, 2018Guru - Experienced User
FYI, the Orbi system is not a business class router, it's a home class product.
If your in a business with business critical networking, then you should be using a business class router product, not a home class.
https://www.netgear.com/business/
Of course I agree with that...
