famousdavis
Aug 19, 2018Tutor
OpenVPN warning: No server certificate verification method has been enabled
Hi, I've got a new Orbi router (Model RBR20) and two satellites. The router's firmware is V2.1.4.16. I enabled OpenVPN on the Orbi router and it works fine with my mobile device. When I use OpenVP...
- Mar 02, 2019
try adding
remote-cert-tls server
to the end of your config file that should remove the warning
sfbayjeff
Dec 06, 2018Aspirant
RBR50 with single Satallite on the latest V2.2.1.210 and same issue on Windows 10. This issue was reported back in August so is there a work around or fix? I don't see any newer firmeware updates to help. Please advise, thank you.
Enygma0
Dec 25, 2018Aspirant
I am having the same issue with openvpn service on v2.2.1.210 as well. my W10 client openvpn is stating "WARNING: No server certificate verification method has been enabled." Is there a firmware fix for this and can you send me a DM to fix this issue?
Thanks.
- j15Dec 26, 2018Aspirant
I'm having the same problem. Here is the info about my router:
Hardware Version RBR40
Firmware Version V2.2.1.210I also have 1 satelite. Here is the message I'm getting:
Wed Dec 26 12:10:43 2018 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
That web page was of no help. If there is a solution to this problem, please let me know. One of the reasons I purchased the Orbi over one of the other mesh routers out there was that it included a VPN service and now that service isn't working (and never has).
Thank you,
Daniel
- FURRYe38Dec 26, 2018Guru - Experienced User
I recommend you contact NG support about this.
Thank you,
Daniel
- Enygma0Dec 28, 2018Aspirant
FURRYe38 , No offense, but I would rather not spend 1+ hrs on the phone to hear a support agent who doesnt understand what openvpn is ask me to factory reset my router even though I just bought it fresh out of the box just a week ago and havent tweaked anything..... I guess this is what you get for spending close to 400$ on a high end product.
