famousdavis
Aug 19, 2018Tutor
OpenVPN warning: No server certificate verification method has been enabled
Hi, I've got a new Orbi router (Model RBR20) and two satellites. The router's firmware is V2.1.4.16. I enabled OpenVPN on the Orbi router and it works fine with my mobile device. When I use OpenVP...
- Mar 02, 2019
try adding
remote-cert-tls server
to the end of your config file that should remove the warning
Enygma0
Dec 25, 2018Aspirant
I am having the same issue with openvpn service on v2.2.1.210 as well. my W10 client openvpn is stating "WARNING: No server certificate verification method has been enabled." Is there a firmware fix for this and can you send me a DM to fix this issue?
Thanks.
j15
Dec 26, 2018Aspirant
I'm having the same problem. Here is the info about my router:
Hardware Version RBR40
Firmware Version V2.2.1.210
I also have 1 satelite. Here is the message I'm getting:
Wed Dec 26 12:10:43 2018 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
That web page was of no help. If there is a solution to this problem, please let me know. One of the reasons I purchased the Orbi over one of the other mesh routers out there was that it included a VPN service and now that service isn't working (and never has).
Thank you,
Daniel
