famousdavis
Aug 19, 2018Tutor
OpenVPN warning: No server certificate verification method has been enabled
Hi, I've got a new Orbi router (Model RBR20) and two satellites. The router's firmware is V2.1.4.16. I enabled OpenVPN on the Orbi router and it works fine with my mobile device. When I use OpenVP...
- Mar 02, 2019
try adding
remote-cert-tls server
to the end of your config file that should remove the warning
Enygma0
Jan 07, 2019Aspirant
Does anyone from support who can actually help actually read these forums? I've been looking and hoping tagging someone on this forum might actually get someone to PM me with hopefully a link to grab some firmware or something.... Ive been needing to use the VPN feature on my router and if that doesn't work this is a deal breaker for me and I need to return my Orbi and go Velop instead.
famousdavis
Jan 07, 2019Tutor
To my knowledge, this issue has never been resolved, and the tech support will only offer fruitless suggestions, like, reset the router back to factory settings.
I’ve just learned to live with a suboptimal solution, as it’s still better than browsing on an open network.
