famousdavis
Aug 19, 2018Tutor
OpenVPN warning: No server certificate verification method has been enabled
Hi, I've got a new Orbi router (Model RBR20) and two satellites. The router's firmware is V2.1.4.16. I enabled OpenVPN on the Orbi router and it works fine with my mobile device. When I use OpenVP...
- Mar 02, 2019
try adding
remote-cert-tls server
to the end of your config file that should remove the warning
rnederhorst
Oct 17, 2018Aspirant
I too would like a solution for the Win10 issue. Any help here?
Thanks!
Rob
funsurfer
Mar 02, 2019Initiate
try adding
- famousdavisMar 07, 2019Tutor
That suggestion -- adding 'remote-cert-tls server' at the end of the OpenVPN config file -- worked! No more 'No server certificate verification method has been enabled' warning message!
I do get another warning -- 'WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this' -- but Googling this one seems not to be a big concern to me.
Thank you, funsurfer! :)
