famousdavis
Aug 19, 2018Tutor
OpenVPN warning: No server certificate verification method has been enabled
Hi, I've got a new Orbi router (Model RBR20) and two satellites. The router's firmware is V2.1.4.16. I enabled OpenVPN on the Orbi router and it works fine with my mobile device. When I use OpenVP...
- Mar 02, 2019
try adding
remote-cert-tls server
to the end of your config file that should remove the warning
CrimpOn
Dec 10, 2023Guru - Experienced User
Thanks for the details.
- nmap cannot detect OpenVPN from the LAN side. useful tool much of the time, but not for this.
- the Android phone providing the Hot Spot was disconnected from the Orbi LAN WiFi ... correct?
brian1918
Dec 10, 2023Aspirant
Correct - the android was disconnected from the wifi LAN connection. Thanks.
