beckss1
Mar 04, 2022Tutor
Optical connection
Dear gurus., I planning to change conenction from ADSL to optical and I see that in Orbi Router port is not exist. I also read note, that ORBI need to be connected via Ethernet cabel, but I see that...
Mar 04, 2022Guru - Experienced User
Most fibre providers give you either an ONT or a gateway that converts from fibre to ethernet.
Before buying anything, I'd check with your ISP on what they're going to provide.
